fuel tap / tank
fat nick
Has thanked: 61 times
Been thanked: 28 times
fuel tap / tank
Post by fat nick » Sat Jan 19, 2019 10:18 pm
Just a quick check .. am I right in assuming ( yes that word) that, there is no difference in 750/100/1100 fuel tank hence fuel taps ?? Robinsons seem to quote same P/N for Taps for all models ?? As I am told my Kat 750 was an import ( captive bolts for front engine mounts ) is this the same ?? thanx for any light you can shed on this :)
:ugeek:
KOC 291
Has thanked: 266 times
Been thanked: 365 times
Re: fuel tap / tank
Post by johnr » Sat Jan 19, 2019 11:16 pm
theyre all imports!
captive bolts for front mounts indicates its an sd frame as the earlier sz's have the bolt going through the frame with a nut on the other side, sd's have a captive threaded insert that th bolt screws into. but, yes, fuel taps are all the same!
Has thanked: 139 times
Been thanked: 685 times
Re: fuel tap / tank
Post by fossie » Sat Jan 19, 2019 11:48 pm
Yep I got a couple of fuel taps from eBay for the 250 and pop up , both less than £15 each Just put in Suzuki GS Fuel tap, they look like the older ones but fit and work.
fat nick
Re: fuel tap / tank
Post by fat nick » Sun Jan 20, 2019 12:18 am
Thanx guys. I now know that I prob need to upgrade to a pingel tap for the mixxy blob so anyone need a perfectly good tap ??
:ugeek:
KOC 291
jmac
Been thanked: 84 times
Re: fuel tap / tank
Post by jmac » Mon Jan 21, 2019 6:51 pm
If you've still got the fuel tap by the Mancee, I'll swap you for a beer or three.
