Front Brake Master Cylinder
ronjeremy
Post by ronjeremy » Sat Apr 30, 2011 10:06 am
Hi folks, does anyone know where I can find a front brake master cylinder repair kit? Brakes are well soft on my GSX1100s so I changed the front hoses for goodrige ones but it hasn't made the brakes much better. The brake lever can be almost pulled to the bar and stopping power isn't great so I'm assuming the master cylinder is the cause. When I pull the lever back it does hold pressure but like I say it doesn't stop well.
Also, has anybody tried fitting a master cylinder from another bike? My GPz900 one looks like it'll slot on!
Cheers.
Re: Front Brake Master Cylinder
Post by johnr » Sat Apr 30, 2011 2:58 pm
most late model suzuki ones will fit. iirc bandit ones seem popular mods.
ronjeremy
Post by ronjeremy » Sat Apr 30, 2011 3:24 pm
Ta old bean
Post by johnr » Sat Apr 30, 2011 4:11 pm
depends what bars you have. many sportsbike ones will work ok, but are angled cos of the low bars fitted to them. bandit ones are more flat topped so sit better on flatter bars. otherwise you can go the whole hog and fit something modern with a seperate reservoir and then it matters little about the angle of the bars.
Post by fossie » Sat Apr 30, 2011 11:00 pm
Wemoto do a repair kit.
ronjeremy
Post by ronjeremy » Sun May 01, 2011 9:36 am
I could only find the kit for the rear brake on Wemoto, do you have a link to it?
ronjeremy
Post by ronjeremy » Sun May 01, 2011 9:37 am
and got the standard 1100s Katana bars fitted
outrage
Post by outrage » Mon May 02, 2011 5:59 pm
I tried fitting a replacement clutch master cylinder kit to me Kat and it didnt work. I spent hours trying to bleed it with brand new internal parts to no avail.
In the end i decided to replace both master cylinders with modern Hayabusa items which also gave me a wide choice of after market levers as i really hated the standards.
dave309
Post by dave309 » Tue May 03, 2011 6:22 am
have a look at your brake leaver somethimes the hole gets a bit oval it will give the same symptoms i had the same problem years ago and took ages to sort stock suzuki leavers ave a little bush in them to stop the wear most after maret ones dont. a half p piece was often used to take up the slack,a bodge i know but it works.
Dave
ronjeremy
Post by ronjeremy » Thu May 05, 2011 12:10 pm
Cheers Dave. With the front wheel clear of the ground and rotated, it does take some lever movement before the brake bites. I pulled the lever off before posting and did toy with the idea of fitting a small washer on the end of the master cylinder piston. The only thing that stopped me was the thought of it jamming on!
