550 clutch plate change....
Russbusa
Re: 550 clutch plate change....
Post by Russbusa » Fri Nov 18, 2011 2:33 pm
Pete, why do you want to change the clutch? I thought you would have to be using it to need that done ???? Top tip is to practice on the Impulse then if you bugger it up leave the Kat well alone :lol:
Post by sparki » Fri Nov 18, 2011 4:08 pm
callyboy wrote:
johnr wrote:check the basket for wear ridges, and make sure the metal plates dont have sharp edges worn on em. soak the new plates in engine oil overnight before fitting.
Watcha John,
If there are ridges and sharp edges, what do you do ? emery cloth em or new ?
give em a rub... if they are still crap then replace 'em
russ talks sense ;)
