Valve clearance on 400 ssn
Re: Valve clearance on 400 ssn
Post by fossie » Sun May 13, 2012 7:03 pm
The easiest way is to do the valves, is individually , just get the cam lobe to the highest point , takes longer but that way you can remember which are done.
Too late now but the tool we have here, along with other sizes.
No need to take rad off but you do need to disconnect top hose , so just drain bottom hose into a bucket and refill after.
