Pop up rear shock adjuster.
KatanaBob
Been thanked: 4 times
Re: Pop up rear shock adjuster.
Post by KatanaBob » Tue Dec 20, 2016 9:40 pm
Googling the SF says it had two shocks?! Anyway, the mystery of my shock remains! There are no numbers.
So i thought, what the hell, why not try rebuild it?
Turns out, the shock was definitely oil dampened and the knob was what regulated the oil pressure. So i re-filled the shock, bled it and filled the regulator. Bled the whole system and now i have an Awesome Shock!!!
It responds really well to the regulator and feels great! :)
Worth freezing my ass off in -5 degrees to get the job done ;)
Sent from my SM-G900F using Tapatalk
Post by fossie » Tue Dec 20, 2016 11:57 pm
Excellent news there chap. I went out in 3 degrees to check my other pop up and found that the shock is as yours. The braided hose on yours is a replacement .
So never across anyone refilling one before so well done , maybe a tutorial for the newsletter is a good article.
The cable referred to is mainly fitted to the Es version which had rebound aswell, these were found on some pop ups.
Again pat on the back sir.
KatanaBob
Post by KatanaBob » Wed Dec 21, 2016 11:28 am
Thanks! I guess time will tell if the rebuild works or not?!
I'll test it a bit more then put together a little "how to" for everyone else :)
