Starter motor noise on starting
Has thanked: 122 times
Re: Starter motor noise on starting
Post by Kryten » Sat May 20, 2023 9:51 pm
Hi Bob
Have you had the starter motor out?
It could be the bearings in the motor
Post by Smallkat » Sun May 21, 2023 4:51 pm
Hmm... that's an odd one then.
As you say, keep going until it doesn't. At least it's easy to bump-start.
Has thanked: 644 times
Been thanked: 247 times
Post by Uncle Bob » Sun May 21, 2023 8:59 pm
Not yet, I think I'll give that a try. A customer of mine runs MotoElectrical and they have the starter motor as same as GSF400 Bandit (Denso) so I should get some discount and they are only near Attleborough so I can go and pick it up. :D
The starter motor did have a harder time last year until I realised it was the Ignitor playing up and got the new Chinese one.
Post by Smallkat » Mon May 22, 2023 10:29 am
JohnD says starter motors readily available!
Post by fossie » Mon May 22, 2023 7:51 pm
As I posted elsewhere I believe ...my 650 does this every now and then ....like to day . ;)
It's the sprang clutch releasing slower than usual ...its been like that since I've owned it ....its no got worse ....r better :lol:
Post by Uncle Bob » Mon May 22, 2023 9:22 pm
I haven't tried bump starting it (so far not needed to) :shock: - I take it you have had some practice...!
Post by Smallkat » Thu May 25, 2023 10:49 am
Many years ago, I had a Bandit 1200 that had a dicky battery, had to bump start for a few days whilst waiting for a new one.
If a little 'un like me can bump a 1200, the 400 should be no problem.
Post by pookie » Thu May 25, 2023 6:55 pm
Helps if you live at the top of a hill :)
Post by Uncle Bob » Wed Jul 12, 2023 9:37 am
So after swapping the sprag clutch rollers etc and that not fixing the strange noise issue, I then decided to replace the 1 year old MotoBatt battery for a Exide Li-ion one from Tayna (heck that is light!) as the MotoBatt didn't sound like it was turning the engine over that fast and also every now and then it would stutter to turn. I also decided to swap the starter motor (which I got from a customer of mine who has an ATV parts business with a side shop called MotoElectrical (starter motor is the same as listed for the GSF600 Bandit). That seems to have fixed it and also the 400 starts bloody quickly now (and we know 400's like to have the odd starting issue)!
Below is a startup from cold after left standing 2 weeks. I did put the fuel tap on Prime for a few minutes prior to starting.
https://www.youtube.com/watch?v=05uDekJgWXY
Next time I'll test without priming the carbs and also we'll see how it goes once the weather starts to get colder. So if you are having starting issues (surely not!) then I can recommend a new starter and the Exide Li-ion battery :-)
Post by Smallkat » Wed Jul 12, 2023 11:42 am
Ooh, that did start right up!
Does that Li-ion battery come in the same size case?
What's the cost?
