650 fuel tank...
650 fuel tank...
Post by callyboy » Fri Sep 16, 2011 7:32 am
I did ask about this a while back but forgot what the answer was :oops:
I got a nice cheap tank on ebay for my 550 but the tank appears to be a 650 one as it has the fuel sender thing attached. However on the otherside of the tank (opposite the fuel tap) there is another small pipe coming out of the tank. Whats that for ?
Been thanked: 715 times
Re: 650 fuel tank...
Post by fossie » Fri Sep 16, 2011 7:52 pm
Hmmmm there shouldn't be another pipe , unless it is for the water overflow from under the cap. BUT the 550/650 didn't have one.
Either way it is just goes to nowhere , it is a breather/ water vent.
Give us a picture.
Post by callyboy » Fri Sep 16, 2011 8:05 pm
Will do fossie. Will take a pic tomoz tomoz.
Only thing i can think of its a pipe to draw petrol from that side of the tank.
Petet
Post by fossie » Sat Sep 17, 2011 10:13 am
No, Suzuki never fitted twin draw pipe to bikes in the 70's or 80's or since i believe.
The pipe can only be an overflow pipe as fitted to pop up /400/250 etc.
Post by callyboy » Sat Sep 17, 2011 10:38 am
Post by callyboy » Sat Sep 17, 2011 3:46 pm
Was thinking the same Mick.
Post by fossie » Sat Sep 17, 2011 5:47 pm
Thats the over flow from the fuel sender.
which means it is from a 83- 84 model gz or mz 650 or 550.
It goes Nowhere pete believe me it is just a breather.
Post by sparki » Sat Sep 17, 2011 9:26 pm
the fuel gauge sender is under there isn't it?..... that "cover" with a pipe out of it is in case the sender seal leaks... the "vent" should have a pipe on it that leads away from a hot engine.
the sender itself has a seal and that cover also has a seal. if the sender seal starts to leak that secondly sealed "vent" catches what has leaked and it's pipe takes it away
Post by callyboy » Sun Sep 18, 2011 7:29 am
Cheers lads. Will stick a hose on it and route it somewhere safe.
