1100 engine into 750s2 electrical bits / wiring differences?
- Katgeezer
Re: 1100 engine into 750s2 electrical bits / wiring differen
You might need the cdi but I'm not 100% on that. Think that's about it.
- Has thanked: 120 times
Apparently not required, as the 750 is alledgedly the same. But you might as well put a Dyna system in at the same time. Just a bit of wiring mods to connect the Tacho.Katgeezer wrote:You might need the cdi but I'm not 100% on that. Think that's about it.
About the only other wiring difference is the use of Self Cancelling Indicators some of the 1100's
