heated jacket
Russbusa
heated jacket
Here's the link for the diy jacket / vest info
http://www.hastie.org.uk/heatedjacket.html" onclick="window.open(this.href);return false;
I actually used 6 metres of the stated wire wire which gave 3 ohms resistance = 65 watts of heat which will be very welcome on all but the warmest of our lovely inclement weather.
I wish I'd found/thought of this years ago !
Re: heated jacket
Russbusa......................................more like rumplestiltskin !
HOT !
Bobster
HOT !
Bobster
Re: heated jacket
No...Rumplestitskin was a magic elf who used a spinning wheel to turn straw onto golden thread.....Bit like you sitting at home weaving your magic....Ok sowing your heated jacket up then...........
Do you not know your fairy tales Russ?
I have just got visions of the Rec reg going T*ts up and dumping all those DC volts through your electric vest........
Russbusa
Re: heated jacket
If the reg rec went ti*s up the voltage would increase and mr ohm would do his magic and increase the current, as its drawing 4.75 amps to start with the 5 amp inline fuse would soon go pop and i'd get cold pretty quick .
Or on a fairy tale note I wouldnt fly too close to the sun and have my wings drop off like Icarus
