1100 rotors
- lomsavage
- Has thanked: 3 times
- Been thanked: 28 times
1100 rotors
Any other models match the 1100 rotors
Gs/ et/ esd / efe etc
Hello from H
- Katgeezer
Re: 1100 rotors
'H', do you mean for the stud spacings or the actual rotor cos you want to swap it out or something?
- lomsavage
Re: 1100 rotors
Actual alternator rotor, need one for the 1327 motor
Hello from H
Re: 1100 rotors
there were different sizes in the 11 motor... what's the inner diameter of the one thats in there now? if there isn't one in there now then whats the outer diameter of the alternator that needs to fit inside it?
think efe was the same as an SD/ESD black motor though...
- lomsavage
Re: 1100 rotors
sorry to be awkward,
not got either piece,
H
H
Hello from H
- Katgeezer
Re: 1100 rotors
Early 1100's have a rotor of 130mm diameter, Kat's use 118mm diameter.
Think later model's are the same but can't confirm.
Not the greatest help mate but it's all I've got.
- lomsavage
Re: 1100 rotors
110X - 125sparki wrote:which ver of the motor is it then?.... engine number?
This help
H
Hello from H
Re: 1100 rotors
don't have one of those in pieces atm... do you have the alternator cover handy? what's the hole size of the centre bit that the alternator mounts on?.... if we know thats inner diameter we can find it's outer diameter.... and the know the inner of the rotor itself... whew...
Russbusa
Re: 1100 rotors
sparki wrote:.... if we know thats inner diameter we can find it's outer diameter.... and the know the inner of the rotor itself... whew...
did anybody else get it !
