Sprocket carrier options ?
Post by Pop-Kat » Mon Feb 21, 2011 10:04 pm
I have a gsxr1100L rear wheel and arm that i'm (slowly) putting in my popup, would a 750/1000/1100 (think they're all the same) sprocket carrier fit the gsxr wheel and spindle size ? has anyone done a similar mod ?
The popup has the same measurement at swingarm pivot at approx 226-8mm..
Been thanked: 201 times
Re: Sprocket carrier options ?
Post by Pedda » Tue Feb 22, 2011 5:28 pm
If memory serves me right, the sprocket carriers are swappable.
Post by Pop-Kat » Tue Feb 22, 2011 6:12 pm
Cheers Pedda, might take a punt on it then, looked on that other thread about rear wheel swaps and you said on there that you used the kat carrier on a bandit12 rear wheel, i reckon the 1100L wheel must be very similar (just curved spokes i think)...
Post by johnr » Tue Feb 22, 2011 7:05 pm
iirc gs500 one fits and is narrower.
Poochy
Post by Poochy » Wed Feb 23, 2011 3:10 pm
Be aware that some of the early 750 slingshots had a 5 segment cush drive whereas the others (later 750 and all 1100) had a 6 segment cush drive.
Post by Pop-Kat » Wed Feb 23, 2011 8:15 pm
Cheers chaps.
BigLT
Has thanked: 1 time
Been thanked: 3 times
Post by BigLT » Tue Mar 15, 2011 12:12 am
I'm using a 5.5'' wheel. I'm looking at getting a gs500 rear sprocket carrier as recommended by a few people. Problem is, there seem to be a lot of different models spread over a number of years. Which one should I look for?
thanks
Liam
