gasket set
gasket set
Post by callyboy » Mon Jan 28, 2013 6:55 pm
need quite a few gaskets for my pop up. Might as well get a full set.I see there is a full set on ebay for £100. Anyone know anywhere cheaper please ?
Re: gasket set
Post by Pop-Kat » Mon Jan 28, 2013 8:16 pm
There's a head gasket on ebay now i think, look under gsx750.
Pattern parts ok for most stuff but original is best for head and base.
Give robinsons a shout i think the gaskets you'll need are cheaper than you think..
gen cover, clutch cover, top brather cover..you shouldn't need the cam cover seal, but that won't be in any gasket st anyway.. you will need new rubber washers for all your cam cover bolts though, and again these won't be in a gasket set.
Re: gasket set
Post by callyboy » Mon Jan 28, 2013 10:14 pm
cheers Mal, will have a look. I need the genny cover and ignition cover ones.Plus zorst gaskets and cam cover and sump ones.Is it worth buying a whole set do you think? Do I need camcover bolt ones as well then?
Re: gasket set
Post by Katgeezer » Tue Jan 29, 2013 10:30 am
Those gaskets would be perfectly ok from a pattern set so price up Suzook OEM ones individually and you'll probably find you can get a complete pattern set for the same price. Don't forget that those particular ones would be the same as ES so it helps widen your search a bit.
Re: gasket set
Post by callyboy » Tue Jan 29, 2013 12:53 pm
cheers chris. do i need to use new cam cover bolt ones?
will prob get a whole set and flog the rest if anyone wants them.
Re: gasket set
Post by johnr » Tue Jan 29, 2013 4:52 pm
http://www.ebay.co.uk/itm/80-82-SUZUKI- ... 1e7384d534" onclick="window.open(this.href);return false;
any use. look at his other stuff, he has loads of kit and its very very cheap!
Re: gasket set
Post by callyboy » Tue Jan 29, 2013 5:38 pm
cheers John, I got a set earlier today. Its not complete but should have most of what i want. £34
Re: gasket set
Post by Pop-Kat » Tue Jan 29, 2013 5:40 pm
I'd be surprised if the cam cover seal is in any gasket set, but check. IMO you will need the cam cover bolt rubber washers, they go rock hard over the years. Do your research Pete, you only need 3 or 4 paper gaskets so may be cheaper to buy genuine. Exhaust gaskets are cheap on eBay one size fits many makes and models of bike.
Re: gasket set
Post by callyboy » Tue Jan 29, 2013 6:31 pm
I got this one Mal:
http://www.ebay.co.uk/itm/221177513912? ... 1497.l2649" onclick="window.open(this.href);return false;
Looks like it has zorst ones as well.
Re: gasket set
Post by Pop-Kat » Tue Jan 29, 2013 6:44 pm
Bargain for genuine, good find, even better if it's got your rubber washers ;)
