Katman wrote:If you want I can see if the seller that I bought the frame for you from, has any 250 parts?
cheers my dears , i don't feel that it is vital but whats the point of 17000 revs when you can only get 13.5? *burned cumberland sausages*.
So yes A 250 CDI would be good.
you were correct all them moths ago , the small bits of fairing bracket from Radiator to arms are missing and not same as 400 at all. I will make some in time if I can't find them.
I suspect the 250 cdi was that number you quoted 32900 means cdi 45D00 is the code for the 250 ssn , this means that this was the first machine this part was fitted to , all i need to do is find out what 39E21 was! and know that it fits the 400, also.
cheers katman.
