Is the carbs on 400 ssn are compatible with other model?
superfly
Post by superfly » Thu Apr 14, 2011 10:06 pm
Basically everything is in the title, I am trying to source some part for my carbs.
and I am wondering if it will be the same on other carbs.
I went to a supplier which is telling me he can't have those parts.
What do you reckon?
Arnaud
Re: Is the carbs on 400 ssn are compatible with other model?
Post by johnr » Thu Apr 14, 2011 11:55 pm
what are you after? 400 carbs are similar in many ways to 250 carbs, theyre also essentially the same as the later model 400 impulse carbs,
superfly
Post by superfly » Fri Apr 15, 2011 7:54 pm
I am just looking for the rubber gasket on bottom, and the bolt all arround.
Nothing to fancy, I would hqve thought it would be easy to get.
Been thanked: 714 times
Post by fossie » Sun Apr 17, 2011 8:55 pm
Can't imagine why you can't get the float bowl gasket.
Phone NRP in manchester 0161 832 8646 and ask for Andy . tell him you are a member of the katana owners club and he'll sort it for you.
superfly
Post by superfly » Mon Apr 18, 2011 8:44 am
Thanks for the info fossie.
I will add that to my list of usefull number, I will call him tomorow if I can get the local shop to get me this.
About the carbs, on the float there is a couple of rubber ring, do you know if they are standard O ring?
On the problematic carb it is a normal O ring on the float and the float does not seem to seat proprely. which I think could be the problem.
what do you think?
Post by fossie » Mon Apr 18, 2011 9:36 pm
In all honesty an o ring is an o ring except the ones in the carbs need to be fuel restisant, also if the o ring is slightly thicker the float won't seat , so yes it would make difference as the float hieght would be different to the rest allowing in more fuel than metered
superfly
Post by superfly » Wed Apr 20, 2011 12:44 pm
For info guys, I get around the fact to ring suzuki Ireland for the price of my parts.
So for the 4*float bowl seal and the 2 o-ring on each float, total is €60 incl VAT.
In NRP, they have 2 kit one at £8 which contain all the seal in the carb except the float valve ring, and for £16 with all the seal include the float valve ring.
So I prefer a lot more the NRP price.
I need to do up a list of thing I need. :-)
superfly
Post by superfly » Thu Apr 21, 2011 10:08 am
I have just made the order to NRP, and got the £80 bill.
Hopefully this and a good clean will sort out my carbs problem.
The guy where very nice, I have to say and took the time to explain think to me. :D
