Led Indicators
kiwi k
Led Indicators
Post by kiwi k » Sat May 10, 2014 7:19 pm
Right tried a forum search and got nothing :(
So my question is My little 750 baby Kat passed it's Mot this week, but got advised no indicators (legally not required).
But yes i was going to install Mini Led indicators just because i feel safer, so being as the Kat has a indicator relay can i just replace that with a 12volt Led flasher relay and then fit Led indicators, and will they then flash as normal.
Most of the internet searching i have done leads me to belive i'm right :roll:
So to Ash or anyone else who has allready done Led indicators can you please CONFIRM if i'm right :mrgreen: .
Re: Led Indicators
Post by callyboy » Sat May 10, 2014 7:28 pm
Should be ok.
Has thanked: 119 times
Re: Led Indicators
Post by Kryten » Sun May 11, 2014 8:46 am
As I understand the LED indicators will work but the flash rate will be very fast.
This is due to the low current draw making the relay think there is a lamp failed.
The cure is to fit load resistors in-line with the indicators to bring the load current back up to the original level.
Or you can opt for a LED specific relay.
http://www.ebay.co.uk/itm/FLASHER-RELAY ... 33728a4b5d" onclick="window.open(this.href);return false;
Or 3 pin
http://www.ebay.co.uk/itm/Flasher-Relay ... 51ad69e6dd" onclick="window.open(this.href);return false;
Both fairly common items on weEvil BAY or go to someone like Deamon Tweaks*
Waiting for a "Bus" to take me to Norwich so can't go and check what the pin config is as I've forgotten :roll:
*other purveyors of car and bike bits are available
Re: Led Indicators
Post by johnr » Sun May 11, 2014 4:08 pm
yes, some chinese scooters have led indicators as stock and so have the relays to suit, rather than buying a specific relay for led indicators, you could get a chinese scooter relay for just a couple of quid. last one i bought was from a lifan and cost me £1.75!!
kiwi k
Re: Led Indicators
Post by kiwi k » Sun May 11, 2014 6:08 pm
you read my mind john was looking at chinese Led relay at £1.25 on gaybay, as i am definately going to order Indicators and a relay, plus now going for a H4 Hid front lamp kit Now they are such a small cofined Kit.
mikefido
Re: Led Indicators
Post by mikefido » Wed May 21, 2014 7:34 pm
When I changed mine i did the rear first and fitted resistors then when I got round to doing the front I got a new relay (from here http://www.vehicle-wiring-products.eu/V ... mepage.php" onclick="window.open(this.href);return false;) which plugged straight in as a replacement for the old one.
The only reason people get lost in thought is because it's unfamiliar territory!
