Airbox
Re: Airbox
Post by Katgeezer » Wed May 04, 2011 11:56 am
Yes Mick,should be nice and bendy but harden with age. Try dropping them into hot water as this usually helps soften them up for fitting your carbs back on. Ideally replace them with new but they're not cheap if you can even find them.
Re: Airbox
Post by callyboy » Wed May 04, 2011 12:41 pm
"post removed due to it being total bollocks apparently"
Pete :oops:
Re: Airbox
Post by bobster » Wed May 04, 2011 3:32 pm
Dont take any notice of the KOC Jester :lol: ;) .....Dont use WD40 Mick! They need to be grease free or they will just pop off the carbs as you tighten the clips!..........
Boil them up in a pan of water or even in a pressure cooker for 20 mins, and then re-fit them and the airbox to the carbs as quickly as you can before they go hard again!
Re: Airbox
Post by bobster » Wed May 04, 2011 4:49 pm
Yep that will help !..........or even a heat gun on a low setting! You Dont want to melt your airbox do you!
I do own a hair dryer.............I use it to warm stuff and dry paint when the weathers cold! ;)
Has thanked: 123 times
Been thanked: 258 times
Re: Airbox
Post by Kryten » Thu May 05, 2011 6:42 pm
Hair dryer? Haven't seen one of them in years! :roll:
Re: Airbox
Post by bobster » Thu May 05, 2011 7:32 pm
Pete, go and Pick your dummy back up .............and put it back in your pram! :lol:
God luv ya............you do Try! :)
Try my patience! :lol:
blackdog
Re: Airbox
Post by blackdog » Fri May 06, 2011 11:15 am
Hi
The hair dryer trick works a treat!
its all in place pop the hair dryer in the airfilter hole, let it warm up and on they go!
tried and tested if ther still a bit hard just turn on the dryer for a bit longer!
I tried hot water and ____ me you have to rush your arse of just to find you've burnt your hands and it gone cold!
If your into that sort of thing go for it, I did and thoughly enjoyed it!
Si
