Pop-up dimensions
Has thanked: 136 times
Pop-up dimensions
Post by Nicky Dodds » Tue Nov 17, 2015 1:50 am
Has anyone tried fitting a pop-up in the back of a berlingo van?
Re: Pop-up dimensions
Post by callyboy » Tue Nov 17, 2015 7:33 am
Got one in the back of a Previa :)
GSX 750 SE Katana 1984
Overall Length: 2 190 mm (86.2 in)
Overall Width: 760 mm (29.9 in)
Overall Height: 1 160 mm (45.7 in)
Seat Height: 770 mm (30.3 in)
Ground Clearance: 150 mm (5.9 in)
Wheelbase: 1 510 mm (59.4 in)
Dry Weight: 212 kg (470 lbs)
Engine type: Air/oil-cooled 747 cc inline-4, DOHC, TSCC, 16 valves. 90 hp (66 kW)/ 9,500 rpm, 67,5 Nm/ 8,500 rpm.
Post by Nicky Dodds » Tue Nov 17, 2015 9:46 am
Not got one of them tho pete...
Post by callyboy » Tue Nov 17, 2015 10:05 am
Nicky Dodds wrote:Not got one of them tho pete...
I was just boasting ;)
Post by Katgeezer » Wed Nov 18, 2015 11:12 am
Height wise should be ok I'd have thought but you might have to drop the forks out for the length. Easy enough if the centrestand is present but awkward if not.
Post by sparki » Wed Nov 18, 2015 11:13 am
drop forks through the yokes maybe to lower it or remove the screen?
Post by Nicky Dodds » Wed Nov 18, 2015 9:02 pm
Bikes gone now anyway and the berlingo i could have borrowed apparently has extra seats welded in place.
Never mind...
