Splitting brake callipers
Hootsy
Has thanked: 8 times
Been thanked: 3 times
Post by Hootsy » Mon Feb 13, 2017 11:09 am
I'm rebuilding a pop-up and getting the calipers stripped and repainted will probably be easier if I split the two halves. I know this is not a good idea with some calipers, so does anyone know if it's ok to split the calipers on a pop-up? If so, are there any requirements when reassembling them? Thanks!
Re: Splitting brake callipers
Post by fossie » Mon Feb 13, 2017 10:18 pm
It is perfectly OK to split pop up calipers, just remember the little rubber washer between the 2 haves , with out it they won't work , to this end make sure th recess where it fits doesn't get blocked .
Hootsy
Post by Hootsy » Tue Feb 14, 2017 9:27 am
Many thanks!
jmac
Been thanked: 84 times
Post by jmac » Tue Feb 14, 2017 1:38 pm
I found that the small '0' ring gets very compressed so I would have some replacements ready, just in case.
