250 fork oil.
Been thanked: 714 times
250 fork oil.
Post by fossie » Wed Jan 16, 2019 1:13 am
To save me firing up the old PC that is hidden in the spare room, then digging out the CD ....I thought I would just ask first. :roll:
Fork oil...how much per leg. . :?:
Re: 250 fork oil.
Post by Uncle Bob » Wed Jan 16, 2019 9:22 pm
So my Japanese is wanting a little but it says:
Fork Oil 10 weight - 345cc per leg
Hold the front fork in a vertical position and adjust the fork oil using the special tool (yeah right! a piece of rod with some tape around it) to get a Oil Level air gap of 104mm (NOTE: When adjusting the oil level, remove the fork spring and compress the inner tube fully).
Hope that helps,
Re: 250 fork oil.
Post by fossie » Wed Jan 16, 2019 9:49 pm
Domo arigatou uncle bob san :D quite a lot of oil really.. Which isn't so good as I may not have enough in stock :( ...but new stuff will added to your specs in the coming days . Ta!
Re: 250 fork oil.
Post by PaulD » Thu Jan 17, 2019 12:46 pm
fossie wrote:Domo arigatou uncle bob san :D quite a lot of oil really.. Which isn't so good as I may not have enough in stock :( ...but new stuff will added to your specs in the coming days . Ta!
I might have some 10weight if yer stuck ;)
Re: 250 fork oil.
Post by fossie » Sat Jan 19, 2019 9:47 pm
Cheers Paul , will see what we have .
Then maybe I'll pick it up off you next time I pass you snoozing on Regent Road industrial units :lol: ;)
Re: 250 fork oil.
Post by PaulD » Sun Jan 20, 2019 11:41 am
fossie wrote:Cheers Paul , will see what we have .
Busted :lol:
Let me know if you need it and I’ll ransack the workshop and find it :roll:
Re: 250 fork oil.
Post by fossie » Sun Jan 20, 2019 5:21 pm
So drain the 250 fork oil ....about 34.5 ml came out :shock:
Re: 250 fork oil.
Post by fossie » Tue Jan 22, 2019 9:11 pm
I have this very day acquired 1/2 litre of fork oil to add to my stock so we are good now cheers Paul. :)
