Clutch Gone!
ronjeremy
Clutch Gone!
Post by ronjeremy » Fri May 27, 2011 6:34 pm
Just finished balancing the carbs on my '82 GSX1100sz, pulled the clutch lever to find that it felt disconnected! The handlebar lever operates the lever on the engine but there's no pressure there, the handlebar lever just flops around. Before I pull the clutch cover off tomorrow, any ideas what's occured? Cheers
JACKJABBA
Re: Clutch Gone!
Post by JACKJABBA » Sun May 29, 2011 9:11 am
I would think that either the lever is loose on the pinion, check before you drain the oil and remove the cover or the pinion is worn where it fits to the rack release. Or the circlip has come off of the rack release and its not engaged with the pinion.
Happy times.
GSX1100SZ
RD500LC
RD250LC
VF1000R
KE 125 1976
KOCUK 316
Been thanked: 198 times
Re: Clutch Gone!
Post by Pedda » Mon May 30, 2011 9:54 am
Clutch hub nut off. Just a rough guess.
ronjeremy
Re: Clutch Gone!
Post by ronjeremy » Fri Jun 03, 2011 7:31 am
Cheers for the replies folks. I opened the oil filler cap and could see the clutch arm operating the clutch, so I tried moving the actuating arm back one spline, adjusted the cable tension and....fine! I'd even had problems before getting into neutral from first, now it works perfectly! I'm wondering if the cable conduit had somehow got stuck on the adjustment screw , perhaps the previous owner had just kept adjusting the cable tension, then the conduit finally jumped off. Anyhoo, all perfect now.
Re: Clutch Gone!
Post by Katgeezer » Fri Jun 03, 2011 9:32 am
Nice to see it was a simple fix rather than an expensive strip down :D
