Parking light
Re: Parking light
Well, it's not part of the MOT test so I guess it's not a legal requirement, I get caught out sometimes when locking my bikes up and turn round to see the headlight on because I've turned the key too far!
- Has thanked: 119 times
Re: Parking light
As far as I know there is not a legal requirement. I have the MR2 mod headlight on the Kat and did not bother with the Parking/Marker light at the front. Not been an issue at MOT time.
If it lights are fitted they have to work, so removal of indicators on the Kats is not a problem as they were not, at the time of manufacture, a legal requirement. the same goes for the front brake light switch.
- KeKat
- Has thanked: 3 times
- Been thanked: 44 times
Re: Parking light
If you have the option to use it on your bike it has to have one. The easy way to get round this is to block the key from being able to move to the parking position. Or if you have a handlebar switch with a parking position then block the switch from moving to parking position. I had to do this for a mot on my kat.
This might be bollocks, as the MOT tester was a picky dickhead.
Keith KOC 355
1982 Suzuki GSX1000SZ
1991 Ducati 900SS
1996 Kawasaki ZZR600
2003 Transalp
2004 MV Agusta brutale F4
2003 Cagiva xtra raptor 1000
2012 Triumph Tiger 800
2019 Suzuki GSX-S 1000S
1991 Ducati 900SS
2003 Transalp
- Been thanked: 715 times
Re: Parking light
Yep if switch shows a side light position you must have one ...however if the headlamp has none fitted it can't be tested.
Easiest thing is paint out the s markings on the switch.
