Suzuki GS 650 Katana Rev Counter
craik
Has thanked: 70 times
Been thanked: 17 times
Post by craik » Sun Dec 22, 2019 12:59 pm
Hi,
My 650 Katana is a Japanese import. The rev counter has a high beam and oil light on the fascia.
Are the UK and Japanese rev counters identical in this regard? Or the UK rev counter lacks any lights?
Thanks for any info.
Been thanked: 714 times
Re: Suzuki GS 650 Katana Rev Counter
Post by fossie » Sun Dec 22, 2019 7:17 pm
It isn't because it's a jap import it is because it is GZ model . 83....A 550 83 model will be the same aswell, though now both difficult to source because nobody marks down Gx or GZ when stashing parts .
It may be easier just to acquire a 650 rev counter and swap the actual mechanism over , it is only held in by a couple of screws .......and the needle which pops off reasonably easily.
Post by fossie » Sun Dec 22, 2019 7:37 pm
If this is the route you wish to progress along , then I feel I should be able to furnish a replacement tachometer for your progress . ( watching sense and sensibility . Well it's on the box of moving visuals and I feel that the act of changing channels will take too much effort.!..therefore proper olde English .)
Post by fossie » Sun Dec 22, 2019 8:17 pm
Or if you don't mind white needles .
https://www.ebay.co.uk/itm/Suzuki-GS650 ... Swjwpc1u9E
It does also have mph clocks although up to 80 mph.
You may also need to change the block connectors but not a biggy.
craik
Post by craik » Tue Dec 31, 2019 7:47 pm
Hi Fossie,
Thanks for the info.
Sorry for the late reply. I only just logged back in again.
Do you have one for sale?
Post by fossie » Wed Jan 01, 2020 1:42 am
I will look in the Kat cave in the next few days ......the box marked clox is 3rd shelf , left set of shelves , next to switch gear and levers......see I know where everything is.....but there are a Kats in front of them !
Post by fossie » Sat Jan 04, 2020 12:50 pm
Ok so moved a few bikes ....they all started and ran and sat ticking over :D "you can't beat the smell of carbon monoxide in the morning :) "
BUT it turns out that although there are 3 speedos ....Speedometers ;) there is only 1 tachometer and if is for a GX...so would need to be dismantled anyway. With this in mind I feel I should keep hold of that Sorry .....but the law of sod is lend , sell your last item of something and the day after you will need it :roll: :lol:
Again sorry for a possible non captive fowl chase , but someone else must have a 550/ 650/ 750/ 850
Tachometer that is just waiting for transplant duties .
Jmac?
Has thanked: 118 times
Been thanked: 256 times
Post by Kryten » Mon Jan 06, 2020 6:00 pm
Post by fossie » Mon Jan 06, 2020 8:28 pm
Well it's not a straight fit, but simply swapping over the internals is a relatively easy job, and at make an offer for £25 incl post would be palitable.
