Pop up headlight availability
Hideehole
Post by Hideehole » Wed Feb 19, 2020 12:40 am
Hi does anyone know of a replacement headlight. I've seen a couple of second hand ones but have had no luck with searching using any of the code number on the lenses. Or is it now just a case of get second hand one and hope there are available if and when you need?
Been thanked: 714 times
Re: Pop up headlight availability
Post by fossie » Wed Feb 19, 2020 10:07 am
Unfortunately the actual pop up headlamp is not part of the "parts bin" system used on most Suzuki vehicles . So it is a case of finding a decent second hand item or finding the ones that people may have bought NOS and hoarded :twisted:
Is yours damaged? There will be 2nd hand ones in the club should you be in need of to get yours back on the road.
Hideehole
Post by Hideehole » Wed Feb 19, 2020 11:36 am
Thanks I will keep in mind when I start getting my second up and running.
jmac
Been thanked: 84 times
Post by jmac » Thu Feb 20, 2020 9:17 am
What exactly are you looking for. Is it just the glass lens or the complete unit. I could probably accommodate you with either.
Hideehole
Post by Hideehole » Fri Feb 21, 2020 9:15 pm
Thanks for the offer I will keep you in mind if I strike out.
Kevin
Post by fossie » Fri Feb 28, 2020 12:09 am
Well well well, tonight watching wheeler dealers , they worked on a 1982 Toyota supra , but only 1 headlamp popped up, the mechanic lifted the bonnet to point out the manual winding device ....low and behold exactly the same as the pop up katana ;)
Probably just a rare now though :|
ibrakeformoose
Post by ibrakeformoose » Fri Mar 12, 2021 3:12 pm
I'm after one unless someone knows for sure thay're the same as a Toyota unit?
jmac
Post by jmac » Fri Mar 12, 2021 3:41 pm
Do you want a complete unit (motor et al) or just the lamp. Got either/both.
Post by Bikeazoid » Fri Mar 12, 2021 6:04 pm
I bet Toyota used that in all kinds of other vehicles at the time so the parts counter might have them.
ibrakeformoose
Post by ibrakeformoose » Sat Mar 27, 2021 8:23 am
Just trhe lamp would be good, but I'm happy to take the lot..
