p.m.folder
- Has thanked: 123 times
- Been thanked: 258 times
Re: p.m.folder
OK.
Go to Private Messages.
And head to the last page of your messages.
On the right hand side of the message line you will see a little square button
Mouse over and click each message you want to delete. Or tap if you’re using a touchy-feely screen.
Then at the bottom of the screen there is a pull down menu. Select <Delete Marked>
Then answer “Yes” to the next <Do you really want to do that, Dave?> message
Then they should disappear into the ether...
- katmarch
- Has thanked: 9 times
- Been thanked: 115 times
Re: p.m.folder
As in...
HAL: “... I’m sorry, Dave I can’t let you do that!”
