pop-up wire electrics.
my pop-up is back on the road, but with one teeny-weeny problem. no neutral light. I've traced the blue wire from the sender on the o/side through to near the fuse box are where it ends in a bare wire just flapping in the wind. The diagram says it goes to the neutral light switch but doesn't show where said switch is located. Constructive comments would be welcome.
Re: pop-up wire electrics.
neutral switches are normally located on the end of the shift drum on old Suzukis.
- Has thanked: 120 times
Yep! Just by the front sprocket to catch all the lube and road dirt
