My 650/1100 jobbie merrily ticked over but when revved cut out ...hmmm started straight away ...wouldn't Rev....grrrrr,
This weekend ..carbs off , obviously expecting debris in the float bowls ...rust ...gunge petrol ..the list was endless in my mind...All came off no issues , float bowls off ...spotless
Started straight away ticked over revved cleanly ...it was that easy!
HOWEVER , obviously I hadn't spent enough time on her( it must be a female) the clutch won't release the drive in gear....it did before all I did was undo the cable to do the carbs!
It was strangely routed by the previous keeper , so I routed it correctly,. The same ..on off on off ...you know how it goes ....finally looked in the spare cables and yep a 650 clutch...too long as they are now generic and the GL model( with ape bars ) covers all, so wasn't holding out much hope
No it worked straight away despite this cable being in storage for at least 12 years ..
WHY ?
Attention seeking obviously .
BigLT ...Hence your gearbox issue ...
