wiring loom.
jmac
Been thanked: 84 times
wiring loom.
Post by jmac » Mon Jan 30, 2023 3:58 pm
Just like me, the loom on my Shark is a bit tired and decrepit, so I'm on the lookout for a replacement.
As the clocks are different to the pop-up, what should I be looking for as in E ES EF and so on.
For the record it comes up as first reg'd 1984. Cheers John.
Re: wiring loom.
Post by fossie » Mon Jan 30, 2023 7:02 pm
jmac
Re: wiring loom.
Post by jmac » Wed Feb 08, 2023 4:28 pm
What's the chances of somebody having a fitting instruction for a Newtronic ignition system. It's the blue/yellow/purple and white wires that I can't figure out. It's worth a pint.
Re: wiring loom.
Post by Smallkat » Wed Feb 08, 2023 10:20 pm
You might need to up the reward. :)
Re: wiring loom.
Post by johnr » Thu Feb 09, 2023 12:37 am
newtronic are just pyranah rebranded.
jmac
Re: wiring loom.
Post by jmac » Thu Feb 09, 2023 9:18 am
(Wiring loom take two.) Has anybody got a copy of a wiring loom for a PYRANAH ignition system. It's the whit/yellow and purple wires that I'm not sure about. It's worth a pint(negotiable).
Has thanked: 122 times
Re: wiring loom.
Post by Kryten » Fri Feb 10, 2023 6:20 pm
Hi John.
You could try this as a start point, best I could find on the world wide webbing!
It’s for a T3 Moto Guzzle, but it may be of use.
9230945.pdf
(574.95 KiB) Downloaded 262 times
Back in the dim and distant past, as it were, I passed a Pirahna/Newtronic ignition system to someone. Can’t remember who though and I do believe the info was fairly slim.
jmac
Re: wiring loom.
Post by jmac » Fri Feb 10, 2023 6:33 pm
Many thanks K, I'll give it a go. what can possibly go wrong?
Re: wiring loom.
Post by pookie » Fri Feb 10, 2023 10:20 pm
I've still got a pirahna alarm by neutronic systems installed on my 1989 Kawasaki kr1 fitted it myself in about 1992 :shock: it's just a mercury switch in a box but is a great bit of nostagia.
jmac
Re: wiring loom.
Post by jmac » Sat Feb 11, 2023 10:32 pm
Cheers P, any chance of describing which coloured wire goes where please ?
