Rear mudguard
KitKa
Rear mudguard
Post by KitKa » Tue May 16, 2023 5:22 am
Hi has anyone got the metal section of the rear mudguard lying around. If they have are they willing to part with it?
Been thanked: 723 times
Re: Rear mudguard
Post by fossie » Tue May 16, 2023 8:56 am
For which model ?
KitKa
Re: Rear mudguard
Post by KitKa » Tue May 16, 2023 10:30 am
You’ve got me there. I assumed from the parts diagram the the part was common to all the pop ups. The rego docs just have it as a 1984 white Suzuki Katana GSX750 the chassis is a GR71D. Hope that helps.
Re: Rear mudguard
Post by fossie » Tue May 16, 2023 1:18 pm
Ah there you go yep there is only one part number for the pop up ...( which at this point we were only assuming ;) )
But yep same as GSX 750 Es ...I may have one but your not really local if I remember :D
KitKa
Re: Rear mudguard
Post by KitKa » Wed May 17, 2023 11:05 pm
Hi Fossie thanks for the reply. I have gone back through various models and have found some better pictures of the part. The ES has a different part number but on closer looking has the same base structure but has two extra lugs welded on. This being the case I now have a new avenue to pursue. Again thanks for replying. By the way starting my own collection 4 pop ups two are immaculate plus the one I’m building.
Cheers hope the summer is good it is wet here (understatement) sheep need life jackets.
