250 fork oil
Tonykat
Has thanked: 16 times
Been thanked: 6 times
250 fork oil
Post by Tonykat » Fri Jun 02, 2023 2:05 pm
Hi, looking to replace my fork seals on the 250, anyone know how much oil in each leg and best oil to use.
Re: 250 fork oil
Post by pookie » Mon Jun 05, 2023 8:40 pm
Check out this Japanese website for servicing the 250 bandit, you might have to use google translate to change the script to English! I use it all the time, the engine, forks and electrics are the same as the 250 Katana, had my fork seals changed by my friendly local mechanic using the info on this site using 10w fork oil
https://sunny.site.kagoshima.jp/bandit/fok-ovh.html
Tonykat
Re: 250 fork oil
Post by Tonykat » Tue Jun 06, 2023 8:43 pm
Thank you, I will check it out👍
