airfilterbox popup kat
peterrr
Post by peterrr » Wed Jun 29, 2011 7:37 pm
right,,, does anyone know how to get the standard airfilterbox in and out of the popup kat?
that is in one piece..
GSX1100SZ, GSX750SF, GSXR1100, GSX750SE popup special
Re: airfilterbox popup kat
Post by bobster » Wed Jun 29, 2011 8:13 pm
I think it will only come out when you take the engine out............So has to go back in the frame before you put the engine back in!
I await to be corrected tho! ;)
Post by Pop-Kat » Wed Jun 29, 2011 8:21 pm
No correction needed, your quite right Rob, engine out to get the airbox in or out.
Post by callyboy » Wed Jun 29, 2011 8:23 pm
Dont popup then ?
Sue the bastards !
peterrr
Post by peterrr » Wed Jun 29, 2011 9:04 pm
bobster wrote:I think it will only come out when you take the engine out............So has to go back in the frame before you put the engine back in!
Engine out? wow not very smart of suzuki to do it like that.
Could not find anything about it in the workshop manual.
Maybe I will try to move the engine foreward a bit and take the intakerubbers off to get some room...
I hope that someone has a better idea then taking the engine out of the frame... :cry:
Post by bobster » Wed Jun 29, 2011 9:14 pm
sais la vie.............
Katman
Post by Katman » Wed Jun 29, 2011 10:04 pm
At least with the 400 one frame rail unbolts, damn pop up doesn't & that engine is one of the tightest fitting engines going.... :evil:
Good luck with getting the bitch out :shock:
lomsavage
Has thanked: 3 times
Been thanked: 28 times
Post by lomsavage » Wed Jun 29, 2011 11:31 pm
just a quick question,
why does it need to come out ??
the answer to that could solve the problem
H
Hello from H
Post by Katgeezer » Thu Jun 30, 2011 9:53 am
Even moving the engine forward doesn't give enough room, it really is an engine out job and as said it's a really tight fit as well, one of the most difficult engines I've ever removed.
Post by Katgeezer » Thu Jun 30, 2011 1:23 pm
Never tried Mick. Can't imagine it being easy.
