Listen up, gearheads. We just got our hands on a new CNC-machined A7075 billet triple tree for the old-school GSX750S Katana, and honestly, the moment it hit the bench, my wrenching instincts completely took over. I couldn't resist tearing down an old factory unit to do a side-by-side caliper check.
The unforgivable weakness of the OEM cast aluminum clamp is the microscopic torsional flex under hard braking—it’s a total joke. But this new piece? The millimeter-level precision on the fork bore is absolutely insane. We are talking aerospace-grade material rigidity. They managed to carve out the unnecessary mass while exponentially increasing the structural integrity against sheer stress. I threw it on the bench vise and hit it with a dial indicator; zero deflection where the factory clamp would normally twist like a wet noodle. It’s built to be absolutely bulletproof.
However, bolting up a front end this relentlessly stiff brings up a completely different beast: thermal expansion. When you're pushing hard and those fork tubes get cooking, the ultra-tight tolerances mean you might run into microscopic binding if you don't account for heat soak traveling up the stanchions.
So, I’ve got a question for you old-school Katana wizards out there: when you're dialing in a hyper-rigid billet front end like this, how are you guys perfectly compensating for the thermal drift between the steel fork tubes and the aluminum clamp under heavy track abuse?
https://japan.webike.net/magazine/custo ... aign=46100
Tearing down the new GSX750S Katana billet triple tree: The OEM flex was a joke.
Moderator: Webike Japan
- Webike Japan
- Has thanked: 4 times
- Been thanked: 6 times
