wiring loom.
Re: wiring loom.
Post by johnr » Wed Feb 22, 2023 11:58 pm
jmac wrote:
Thu Feb 09, 2023 9:18 am
johnr wrote:
Thu Feb 09, 2023 12:37 am
newtronic are just pyranah rebranded.
(Wiring loom take two.) Has anybody got a copy of a wiring loom for a PYRANAH ignition system. It's the whit/yellow and purple wires that I'm not sure about. It's worth a pint(negotiable).
white is live, so an ignition switched +'ve,
blue is earth,
yellow and violet are negative (under no circumstances connect them to the +ve coil side) feeds to the coils. so i guess you will also need a seperate ignition switched +ve to the coils too.
jmac
Been thanked: 84 times
Re: wiring loom.
Post by jmac » Thu Feb 23, 2023 3:29 pm
Cheers John, I'll keep it in mind when or if I get round to fit it. See you at nabd?
Re: wiring loom.
Post by johnr » Wed Mar 01, 2023 12:45 am
aye, we will be at nabd john. see you there.
