Front paddock stands
Katfish
Been thanked: 31 times
Post by Katfish » Wed May 04, 2011 3:24 pm
I am looking at buying a front paddock stand. Never used one before but i am sick of having to take my bikes to work and hang them with ropes from a beam to get the front wheel out.
Has anybody used them? and can recomend what type/make to get, there seem to be quite a few around the net for just under £30 but any advice would be appreciated. :D
Andy...KOC 298
Snap, Crackle & Pop Up
Been thanked: 201 times
Re: Front paddock stands
Post by Pedda » Wed May 04, 2011 5:20 pm
Got two different types. One supports the front beneath the stem, good if you want to take the forks out, too. The other one goes under the forks, just enough to work on the wheel.
Any front paddock stand will require a rear paddock stand to make sure the bike doesn't flip when lifted.
nokatanayet
Post by nokatanayet » Wed May 04, 2011 7:13 pm
i use my micron one, it fits in the stem of the bottom yoke and if you have a center stand you don't need use a rear paddock for the rear
Katman
Post by Katman » Wed May 04, 2011 7:54 pm
Or try an abba stand and car jack/block of wood/abba front stand etc
superfly
Post by superfly » Wed May 11, 2011 10:37 pm
Hi Guys,
I am thinking about getting a front and rear stand, as I need to work on my bike a bit.
But I look at the price of both it is about €70 for both, so I am thinking about using a middle one or make one. A couple of weld should sort this out.
Is anyone try a middle stand by any chance?
Katman
Post by Katman » Wed May 11, 2011 11:26 pm
My bruv looked into welding the brackets on for a centre stand but found it wasn't feasible. I think he said it would foul on the radiator catch (overflow) tank!!
I'll confirm with him tomorrow but I'm sure that was it.
The abba stand that I mentioned is very handy & can be used with other bikes too http://www.abbastands.co.uk/" onclick="window.open(this.href);return false;
Katfish
Post by Katfish » Thu May 12, 2011 4:53 am
Well, I finally bought one that lifted the forks and used it yesterday, worked perfectly and enabled me to remove the front wheel with no problems. Cost £26 including p&p well pleased :)
Andy...KOC 298
