I’m finally reaping the rewards of all the skinned knuckles and swear fests I’ve put in getting the motor up to scratch. This bike is going nowhere anytime soon which is a bit of an about face from when I first got her. I’m enjoying riding it now
Out on Beezlebitch yesterday
Had a cracking ride out on the bitch yesterday. Cold but sunny and dry. Another 150 trouble free miles on the odo
- Has thanked: 119 times
Re: Out on Beezlebitch yesterday
Took Skruffy Kat out for a short run on Friday afternoon. Had a bit of an issue with flooding carbs but fired up and was running well.
I have the opposite problem to you Jim. If I leave the bike for a couple of weeks without using it (quite often) I have to switch the fuel tap to prime or it takes a good few spins on the starter before she fires up. The fuel must evaporate away?
- Been thanked: 715 times
This common with all gravity fed carbs nowadays ..what constitutes as petrol being the issue.
As a natural action nowadays prime for a 30 seconds or so then apply choke and starter is the norm.
Super unleaded makes the left time less , but just another quirk of owning a classic I suppose.
I had both issues. After a couple of weeks lay up it needs to go to Prime to fill the carbs. Then every now and then it floods as the float needles are sticky!
A bit of carb cleaner down the fuel line usually sorts it
- KeKat
- Has thanked: 3 times
- Been thanked: 44 times
Try Profi Fuel-max. It works
Keith KOC 355
1982 Suzuki GSX1000SZ
1991 Ducati 900SS
1996 Kawasaki ZZR600
2003 Transalp
2004 MV Agusta brutale F4
2003 Cagiva xtra raptor 1000
2012 Triumph Tiger 800
2019 Suzuki GSX-S 1000S
1991 Ducati 900SS
2003 Transalp
