Out on Beezlebitch yesterday
Post by PaulD » Fri Feb 07, 2020 9:38 pm
Had a cracking ride out on the bitch yesterday. Cold but sunny and dry. Another 150 trouble free miles on the odo
I’m finally reaping the rewards of all the skinned knuckles and swear fests I’ve put in getting the motor up to scratch. This bike is going nowhere anytime soon which is a bit of an about face from when I first got her. I’m enjoying riding it now 8-)
Has thanked: 119 times
Re: Out on Beezlebitch yesterday
Post by Kryten » Sun Feb 09, 2020 10:02 am
Took Skruffy Kat out for a short run on Friday afternoon. Had a bit of an issue with flooding carbs but fired up and was running well. :D :D
Post by PaulD » Sun Feb 09, 2020 10:25 am
I have the opposite problem to you Jim. If I leave the bike for a couple of weeks without using it (quite often) I have to switch the fuel tap to prime or it takes a good few spins on the starter before she fires up. The fuel must evaporate away?
Been thanked: 715 times
Post by fossie » Sun Feb 09, 2020 10:38 am
This common with all gravity fed carbs nowadays ..what constitutes as petrol being the issue.
As a natural action nowadays prime for a 30 seconds or so then apply choke and starter is the norm.
Super unleaded makes the left time less , but just another quirk of owning a classic I suppose.
Post by Kryten » Sun Feb 09, 2020 11:09 am
I had both issues. After a couple of weeks lay up it needs to go to Prime to fill the carbs. Then every now and then it floods as the float needles are sticky!
A bit of carb cleaner down the fuel line usually sorts it
KeKat
Has thanked: 3 times
Been thanked: 44 times
Post by KeKat » Sat Feb 15, 2020 7:24 pm
Try Profi Fuel-max. It works
Keith KOC 355
1982 Suzuki GSX1000SZ
1991 Ducati 900SS
1996 Kawasaki ZZR600
2003 Transalp
2004 MV Agusta brutale F4
2003 Cagiva xtra raptor 1000
2012 Triumph Tiger 800
2019 Suzuki GSX-S 1000S
