550 footrest position
Nigelkat
Has thanked: 1 time
Post by Nigelkat » Tue Apr 10, 2012 7:44 pm
Hi I need a couple of dimensions for the location of footrests on a std 550 for my project.
Ideally dimension from top frame rail under seat to top of footrest and from centre of swinging arm pivot to front of footrest.
This should give me a starting point to fit something different on my frame.
Nigel
Re: 550 footrest position
Post by callyboy » Tue Apr 10, 2012 7:53 pm
Will try and get some numbers tomoz for you Nigel.
Nigelkat
Has thanked: 1 time
Post by Nigelkat » Tue Apr 10, 2012 8:24 pm
cheers Pete
Russbusa
Post by Russbusa » Tue Apr 10, 2012 9:17 pm
Hi Nigel
80mm from centre of swing arm bolt to centre of footrest bar
395mm from the top of the frame tube to the top of the footrest bar closest to the hinged pin.
sorry Pete, just happened to have the 550 up on the ramp and a tape measure in my hand :)
Post by callyboy » Wed Apr 11, 2012 6:27 am
no probs. cant find my tape measure. And by the looks of things you must have at least 5 of em :)
Nigelkat
Has thanked: 1 time
Post by Nigelkat » Fri Apr 13, 2012 10:28 am
Thanks guys
