Hi I need a couple of dimensions for the location of footrests on a std 550 for my project.
Ideally dimension from top frame rail under seat to top of footrest and from centre of swinging arm pivot to front of footrest.
This should give me a starting point to fit something different on my frame.
Nigel
550 footrest position
Russbusa
Re: 550 footrest position
Hi Nigel
80mm from centre of swing arm bolt to centre of footrest bar
395mm from the top of the frame tube to the top of the footrest bar closest to the hinged pin.
sorry Pete, just happened to have the 550 up on the ramp and a tape measure in my hand
no probs. cant find my tape measure. And by the looks of things you must have at least 5 of em
