front wheel spindle
Re: front wheel spindle
http://simplybearings.co.uk/shop/" onclick="window.open(this.href);return false;
simply search by size and choose the quality you want - crap = cheap, decent = not as cheap
chris44
Pete Deeds is your man in the club otherwise get your measuring stick out theres a guy in bolton i can go and see for you
Ooh eer is that even possible???chris44 wrote:Deeds is your man in the club
OK. Think I have found a place for the bearings(cheers Steve). Now how do you get the old ones out ? Looking inside their isnt a lip or anything to get a screwdriver on and whack em. Do i need a puller ? Most youtube clips are saying push the centre space out of the way to get onto the bearing, but i cant push the space anywhere out of the way.
Get a big screwdriver and lever the spacer over to one side, then you'll need a piece of bar or tubing to knock the bearings out!
simples!
I wonder if this thread is going to be as long as all the other ones...............
simples!
Stop being so cheeky. Gives you lot something to laugh about dont it.
oh....and thanks for the advice.
Get a blowlamp and heat the surrounding area, the bearing will come out much easier once the area its in has expanded, wheels are easy, swingarms a different matter they are a bitch
KOC 49
FBJ
- Has thanked: 5 times
- Been thanked: 31 times
Sometimes you have to tap the spacer. Then use a drift. I use a old knackered 3/8" drive extension bar. Share the tapping of the bearing. Make it equal or u could damage the wheel. Don't be to RAM headed
