Swinging arm bearings, 1100
I want to get my swinging arm bearings out and they are as tight as a crabs arse. Any one got a tip to help them on their way? Or is it just a case of using brute force.
Also does anyone know how much they cost to replace?
On a mission to get it all back together, so that I can get out and come to some of the meetings.
Cheers Jack
Cheers Jack
GSX1100SZ
RD500LC
RD250LC
VF1000R
KE 125 1976
KOCUK 316
RD500LC
RD250LC
VF1000R
KE 125 1976
KOCUK 316
Re: Swinging arm bearings, 1100
Right. Get yourself the biggest hammer you can. Then...................................................................................
I'll get my coat
Ps- i always got em out with a metal bar that you can pop into the tube and rest it on the bearing lip, then whack it with a hammer. Move it around the lip to get the bearing out square.
I'll get my coat
Russbusa
Get something like a 1/2" bar, put a bend in it then grind the end at an angle so that it will pull into the bearing rather than jumping off when you hit it.
Then as callyboy says. . . .. . . . .. . . . . .. . . HIT IT !
But turn the bar to hit around the bearing gradually rather than always in the same spot.
happy bashing !
happy bashing !
- Katgeezer
As for replacements,try any local bearing sales shop as they'll be a fraction of the OE Suzuki ones and exactly the same.All you need is the number off the side of the bearing case.
yup, steel bearing casing and ally swingarm means lovely dissimilar metal corrosion, and theyre wide ones them needle rollers, give em aq soak in something like duck oil for a day or 3 and then get the old heat gun on them first, then, beat the crap out of em with the big hammer!!
you wont get them from a bearing stockist, theyre a special with them being a needle roller, dont forget to renew the bush that goes in them as well, and dont be tempted by the aftermarket nylon bush kits you can buy, theyre only any use for getting them through the mot, cos they wont survive the ride home!!!
- Has thanked: 122 times
Wot Johnr said!
Replaced mine with Gen-you-wine parts
Russbusa
Got my needle bearings from a normal supplier.... cant remeber who. bike bearings web site gives sizes and most american (look on web) suppliers give you the sizes and the bearing number, just looked up a stockist then. I think the swing arm bearings were about £6 each. as for genuine parts. . . . . . I dont think suzuki have their own bearing manufacturing factory. they just buy them. Although "some" bearings are an odd size and manufacturer specific.
Russbusa
Bearing for bikes are here
http://www.z1enterprises.com/" onclick="window.open(this.href);return false; they give the bike and bearing sizes
Then go here and match up the sizes to get the bearing numbers
http://www.marksman-ind.com/" onclick="window.open(this.href);return false;
I got a pair Of swingarm bearings £19.02 delivered
Poochy
Russbusa wrote:Bearing for bikes are here
I got a pair Of swingarm bearings £19.02 delivered![]()
Good work that man!
Some useful links there. Perhaps we could put stuff like this in our technical section when it gets sorted.
