750 differences
750 differences
Hi there Katana back room boffinns!
Here's a question I'm sure has been asked a squillion times, but what's the difference between a 750 and 1100? Is it easy to make a 750 into an 1100?
Ta in advance
Patrick
Ta in advance
Patrick
Re: 750 differences
Remove engine.... Add larger one. Replace bottom engine mounts with ones that fit if you feel like it... Some don't bother with em but they're just a pair of flat plates
FBJ
- Has thanked: 5 times
- Been thanked: 31 times
Re: 750 differences
Rear wheel. If its a s2. Forks. Yokes. Clip ons. Clocks. Only top speed i think. Nothing much
Re: 750 differences
I think a set of 1100 carbs are also needed.........preferably 1100 EFE ones as theyre bigger!
GSX1100 engines are fetching good money so be prepared to shell out at least £500 for one and at least another £80 for carbs.
- Been thanked: 716 times
Re: 750 differences
Just tell everyone it's an 1100 , most people will assume that anyway........ Much easier and cheaper.
Re: 750 differences
There dont seem to be any 1100's around at the moment, and I'm worried as soon as one becomes available i get a tax bill, or summat goes wrong on the house...there is though a 750 on evil bay at the moment!
Re: 750 differences
EFE will yes... Ignition is different but other fine. Just stiick the EFE brains in and you're away
Re: 750 differences
although if you think gsx1100 motors are expensive and rare, just wait till you try to find an efe lump
