clocks
Re: clocks
Post by johnr » Tue Mar 25, 2014 10:28 pm
kph or mph speedo? if kph then 180 kph or 240kph?
Re: clocks
Post by johnr » Fri Mar 28, 2014 10:30 pm
dont try other suzukis from a later date. try other manufacturers bikes from the same era. i know that 1100 goldwings had identical needles to the kay, only they were white, this means they must have been made by the same firm.
Re: clocks
Post by johnr » Sat Mar 29, 2014 8:51 pm
are you a club member?
Re: clocks
Post by sparki » Sat Mar 29, 2014 10:23 pm
profile says.... not yet
Cat
Has thanked: 14 times
Been thanked: 15 times
Re: clocks
Post by Cat » Tue Apr 01, 2014 8:06 pm
She is one now John
Re: clocks
Post by johnr » Wed Apr 09, 2014 4:15 pm
im in the shed tonight working on that pop up motor. i will look in my box of bits.
Re: clocks
Post by johnr » Wed Apr 09, 2014 8:07 pm
you dont need a working speedo for an mot test.
Re: clocks
Post by johnr » Thu Apr 10, 2014 10:29 pm
sort of. ive a kph speedo drive, but im not sure if its got the pin in the centre for the needle to fit to. im gonna compare it to another speedo but that means taking one to bits!
kiwi k
Re: clocks
Post by kiwi k » Thu Apr 17, 2014 5:39 pm
John on my kmh set i have just dismantled the 2 needle shafts are different sizes is that normal? cheers Kiwi.
