Post
by callyboy » Mon Feb 07, 2011 1:49 pm
Tried to start the (cough) Impulse today. Not getting a spark at any spark plugs
Got a multimeter. where do i need to poke it ( watch it !!!) and what should i be getting with regards values ?
Was wondering if its an earth problem again ? Powdercoated frame not earthing coils ?
Very sad
PS- I did swap the coils over for some other ones when i was doing the rebuild. Do you think i should put the original ones back on ? (the reason i swapped was that the original coils were both differant - but they did work !!!).
Katfish
- Been thanked: 29 times
Post
by Katfish » Mon Feb 07, 2011 3:45 pm
Gotta be a good starting point Pete by refitting the coils that you know work.
Post
by callyboy » Mon Feb 07, 2011 3:54 pm
Yeah Andy, think i will try that tonight when kids are in bed. It kinda makes sense eh
Post
by bobster » Mon Feb 07, 2011 4:05 pm
Make sure the coils are earthed to the frame where they are bolted on, use some emery /sand paper and rub /scrape away the powder coating.
Also check the kill switch is switched to ON and working. You need +12Volts at coils terminals on orange wires ( switched live). Also check the wiring from the ignition pickups is connected and all block connectors are clean and not corroded.
And dont forget the fire extinghisher......................
Post
by callyboy » Mon Feb 07, 2011 4:16 pm
Watcha Bobster, dont the negative wires on the coils earth them?
Post
by bobster » Mon Feb 07, 2011 4:43 pm
What negative wires are they then Pete?
You asked for help an I have given you the help you need! You just need to act on it !
The coils have a primary and secondary circuit , or High and Low tension. The Iron coil body has to be earted to the frame, the high tension is triggered by the ignition pickups via the CDI.
Had the same problem in Switzerland when 1 of Flo's Dyna coils failed and the lads tried a suzuki coil but didnt earth it so It looked like it was also fooked.....once it was earthed all was hunky dory!
Now get the paint scraped of like a good little Callyboy...........
God luck!
- Committee Member
- Has thanked: 80 times
- Been thanked: 72 times
Post
by sparki » Mon Feb 07, 2011 5:14 pm
the wires on the coils go to switched live and the black box thing that fires when it needs to.... not earth
- listen to bobster and you'll be fine
Post
by johnr » Mon Feb 07, 2011 7:00 pm
ok, starting at the start.
battery on?
ignition on?
lights on the clocks on? particularly the neutral light, some jap bikes had interlocks to stop them firing up in gear,
press the starter and engine spins?
check all your fuses next, dont forget the one on the solenoid, some bikes have them, some dont.
check that everything is plugged in, particularly the pickups to the cdi,
yes to all these? ok, firstly, has the bike got a sidestand switch? if so, disconnect it and throw it as far away as you can! theyre rubbish! even when new.
now, you get your multimeter and check that you have power to your coils whenever you switch the ignition on. next you need to check the wiring diagram and find out which is the live power feed to the cdi box, check with the multimeter if there is power to the cdi.
then come and tell us what you have found
Katman
Post
by Katman » Mon Feb 07, 2011 7:44 pm
callyboy wrote:Yeah Andy, think i will try that tonight when kids are in bed. It kinda makes sense eh
You wicked man you, starting the bike when the kids are in bed....wouldn't an alarm clock be kinder or will the sofa deaden the noise that much
KOCUK 046 Jez
GSX750S3 ANATAK, GSX400SSN, GSX400
MK2 Impulse frame & an almost complete pile of 400 Kat parts to build a hybrid!! GS650G x 1 3/4...........
to be continued
Post
by callyboy » Wed Feb 09, 2011 9:38 am
