superfly
Post
by superfly » Wed Apr 25, 2012 7:23 pm
[url]
http://www.ebay.co.uk/itm/NEW-WILLIAMS- ... t_1397[url]
Pete you see on that pic, there is a little joint, this will allow you to get there in a blink of a eye.
I would get a little tool set with this in it for the bike it is fantastic with a small rachet, you will love it.
I think it might be hard to get this from the side, as I am not sure you will actually have enough angle to turn the nut.
superfly
Post
by superfly » Thu Apr 26, 2012 7:42 am
You can try but I doubt it will work, it is depending on the room you have Pete to turn the nut and I don't think you will have enough space unfortunately.
My bike start normally this morning no problem... She is driving made....
- Committee Member
- Has thanked: 80 times
- Been thanked: 72 times
Post
by sparki » Thu Apr 26, 2012 10:19 am
the angle on that deep ring is wrong to go in there... willing to bet you're in the same position you are now....
i think what you could do is the same theory as the pic i posted except with a much shorter tube that the screwdriver part goes through. if the tube was short enough to be between the top of the carbs and the frame rails with a shorter screwdriver bit (or a flexi driver) then i recon you'd be onto a winner.... or maybe even you can still use the full length screwdriver?
just ideas.... my kat isn't too bad there... my ET is a really bad angle too though but with a little persuasion all is ok..... gotta get creative!
Katman
Post
by Katman » Thu Apr 26, 2012 10:28 am
KOCUK 046 Jez
GSX750S3 ANATAK, GSX400SSN, GSX400
MK2 Impulse frame & an almost complete pile of 400 Kat parts to build a hybrid!! GS650G x 1 3/4...........
to be continued
Post
by callyboy » Thu Apr 26, 2012 7:28 pm
Understand what your saying steve. Going to stare at it for a couple of hours tomoz if i get a chance. Sometimes works.
Post
by callyboy » Thu Apr 26, 2012 7:50 pm
I need everyone to stare at this for at least half a hour. It might help.
superfly
Post
by superfly » Thu Apr 26, 2012 9:06 pm
Stop staring Pete and try that, get a flat blade screwdriver like the one in every kit and a 8 spanner with a round part should go in, tape the whole lot together and try to move the screw from the side.
You could also use a tube spanner it will be easier you could get a screwdrive at the very hand to get more ease.
Do I make sense ?
If I don't let me know I will go in the garage get some pics for you.
Post
by callyboy » Fri Apr 27, 2012 6:28 am
Got ya Arnaud. Will maybe have a go today.
Russ rekons it shouldnt be a prob getting on that middle adjuster, so i am wondering if maybe i have put the throttle/choke on wrong ? They both work ok.
superfly
Post
by superfly » Fri Apr 27, 2012 8:06 am
Do you have a parts, or manual diagram?
You should be able to see on it, if you put it in the wrong way.
