550 carbs
Re: 550 carbs
Post by callyboy » Sun Apr 29, 2012 7:06 pm
Cheers Jim, take the air box off :shock: :shock: :shock: :shock: :shock: :shock:
You must be joking. :lol: :lol: :lol: Its a nightmare to get the bugger on/off.
:lol: :lol: :lol:
Will have a go tomoz if i get time.
Cheers again.
Been thanked: 716 times
Re: 550 carbs
Post by fossie » Sun Apr 29, 2012 7:26 pm
He said "TAKE THE AIR FILTER OUT, NOT BOX OFF ,"
either way as he said 3 is fixed adjust 2 to it and set 1 and 4 slightly higher. :geek:
Oh and if you'd just said Yes I'd have sent it down the tool to fit the adjusters, with out having to take it apart. because part of the checking the balance is to rev it and see where it settles, difficult if the throttle isn't actually attached to the carbs, I feel. :P
As for the choke knob just disconnect it from the carbs leave it in the headstock so it looks like it works. That way it can't do what it is going to do anyway , :shock: But if you ain't gonna ride it it wont matter. ;)
Has thanked: 120 times
Re: 550 carbs
Post by Kryten » Sun Apr 29, 2012 7:30 pm
callyboy wrote:Cheers Jim, take the air box off :shock: :shock: :shock: :shock: :shock: :shock: ....
The main restriction in air flow into the engine is the Filter, so take that out and balance them all up to No.3
Like wot Fossie says......
Has thanked: 80 times
Been thanked: 72 times
Re: 550 carbs
Post by sparki » Sun Apr 29, 2012 7:41 pm
i've always adjusted mine to be the same.... raise the idle to 1500-1600 revs and then balance them the same imo....
and if it starts taking too long to get it right you may wanna turn off and let it cool down before continuing...
KOCUK - 241
Re: 550 carbs
Post by Kryten » Sun Apr 29, 2012 7:48 pm
sparki wrote:i've always adjusted mine to be the same.... raise the idle to 1500-1600 revs and then balance them the same imo....
There's not a great deal in it. As Suzuki suggest it's the difference of half a ball on their gauges.
And thats sound advice about the engine warming up too much. Do it in 5 minute sessions, with a tea break in between. then after the 4th go. Off to the loo :lol:
Re: 550 carbs
Post by callyboy » Sun Apr 29, 2012 7:50 pm
:oops: :oops: :oops: :oops:
superfly
Re: 550 carbs
Post by superfly » Mon Apr 30, 2012 11:21 am
so pete did you do some magic?
Re: 550 carbs
Post by callyboy » Mon Apr 30, 2012 3:08 pm
This is what I have ended up with:
Had a quick blast up the road before school pick up and the bike seems to be a lot smoother. Also not getting any hesitation on pick up. Doesnt seem to be popping from the exhaust on throttle down either, which it was doing before.
Maybe doing the air screws helped as well.
Will go for an longer run tomoz to give it a better shakedown.
What you rekon ? does it look ok ? I tried to do what you suggested, and make thye outside 2 slightly higher.
superfly
Re: 550 carbs
Post by superfly » Mon Apr 30, 2012 3:50 pm
Well done Pete,
It all seems ok to me, mine need a good look over too. I will do it next weekend as it is a 3 days weekend it will be nice and handy.
Re: 550 carbs
Post by Kryten » Mon Apr 30, 2012 6:56 pm
Hey Pete
That's a big step in the right direction.
If you are happy with how the bike is running then you can leave it at that.
Maybe I'm a bit too particular with these things, but 1 & 4 are low compared with 2 & 3.
Remember we are dealing with vacuum here, so the needles on the gauges need to be further round to indicate a higher vacuum (or Lower Pressure). :geek:
But as Sparki says you can set them all the same and it wont be a kick in the doo dahs out :lol:
