Yeah, I went through the trouble to get the all thing out for not result as I don't have the tool.
So I put everything back in now.
Obviously forgot to measure the little square. So does someone know if it is 3 or 4 mn ?
I saw that little tool :
http://www.ebay.co.uk/itm/HONDA-KAWASA ... rn false;
I have check the valve clearance and it seems to be off. I am not 100% sure of the cam position to do the work.
Based on what I saw on the manual the cam as to be in up position, I also saw that there is a notch at this end of the camshaft so I suppose that if one cam is in up position then the notch as to be a either parallel to the head cover of 90 degree of it.
Do you see what I mean?
