I will get photo of the original one on the Germano 650 tonight but it will be very late.
The original hose is ended if I remember ,ie there is an angled kink in the unions.
650 KAT REAR BRAKE LINE
- Been thanked: 716 times
Re: 650 KAT REAR BRAKE LINE
Just had a thought, you don't say weather it is too long, as most people seem to have a slack near the rear wheel.
The line attachs to the master cyl facing forwards , goes over the swing arm' towards the engine then turns back through torque arm clamp along clamps and there is a slight kink outwards at the calliper end.
You know what I haven't even looked at a bike today so far (but will in 5mins) so I'm full of s..........useless /full info
katscott
- Has thanked: 3 times
- Been thanked: 7 times
OK guys after Fossie's words of wisdom. I routed the hose over the frame rail and everything has lined up how it should. Thanks for the help. Scott
