Stainless bolts needed
chris44
Post by chris44 » Fri Aug 17, 2012 12:25 pm
Hi guys can anyone point me towards M12 x 40mm hex flanged stainless bolts I need 4 thanks in advance
Re: Stainless bolts needed
Post by callyboy » Fri Aug 17, 2012 9:05 pm
maybe:
http://www.ebay.co.uk/itm/50x-M12-X-40M ... _500wt_716" onclick="window.open(this.href);return false;
or I use these peeps:
http://myworld.ebay.co.uk/boltmeup&ssPa ... 1543.l2533" onclick="window.open(this.href);return false;
Sergio
Post by Sergio » Sat Aug 18, 2012 4:23 am
Pardon for a stupid question but is it a big problem to find a bolt in UK?:) In Russia and in Moscow there are plenty of special shops where you can find any bolt you need:)
Suzuki GSX400SSN '93
Honda GL1200 '86
and 4 cats...
chris44
Post by chris44 » Sat Aug 18, 2012 7:38 am
Sergio wrote:Pardon for a stupid question but is it a big problem to find a bolt in UK?:) In Russia and in Moscow there are plenty of special shops where you can find any bolt you need:)
No its just this seems to be a bithard to source cos its flanged stainless and full thread and quite large!!
Pete did you look at the price of the first one £19 :shock: :shock: :shock: oh and its not stainless
mick will ring probolt after work thanks
Post by callyboy » Sat Aug 18, 2012 7:49 am
Watcha Chris, thats for 50 of the buggers though !!!
chris44
Post by chris44 » Sat Aug 18, 2012 12:45 pm
callyboy wrote:Watcha Chris, thats for 50 of the buggers though !!!
Only need four!! Theyre for my front calipers I may have to get a normal hex bolt and washer and threadlock
Chrome would do equally well tho :D
Been thanked: 198 times
Post by Pedda » Tue Aug 21, 2012 11:06 am
If I were you I would not take stainless bolts for your calipers, neither on any other safety relevant parts. Proper steel is much better for that purpose. Not that you'll run into danger in short time, more likely a long term issue about contact corrosion between partner materials of quite different refinement etc.
Has thanked: 120 times
Post by Kryten » Sun Aug 26, 2012 7:53 pm
I agree with Pedda, not only from the corrosion issue, but also from the tensile strength aspect.
chris44
Post by chris44 » Sun Aug 26, 2012 9:40 pm
ok can get steel what about coating? zinc?
jimmy400
Has thanked: 21 times
Been thanked: 25 times
Post by jimmy400 » Mon Aug 27, 2012 7:17 am
chris, have you tried K supplies on vernon st they have all sorts and i'm sure you can buy as few or as many as you want. jimmy
