It looks like I can look forward to another carb strip down then! I thought I had checked them all out throughly and cleaned (before repainting). It's only No 1 cylinder so hopefully I can just take the bowl off to check first off.
Thanks for feedback on the Dyna S - I'll save my money, so it's just a 4-1 for now (plus what I saved I can get some nice new braided brake lines).
Dyna S / DynaCoil / DynaLeads / IRIDIUM Plugs - Worth While?
Pop-Kat
Re: Dyna S / DynaCoil / DynaLeads / IRIDIUM Plugs - Worth Wh
You'll need to have the carbs off to rejet them for the 4-1 pipe, do the two jobs at once
- KeKat
- Has thanked: 3 times
- Been thanked: 44 times
Yep I had the same starting problem after cleaning my carbs, so removed them again, cleaned the float bowl passages, started and ran fine after that.
Keith KOC 355
1982 Suzuki GSX1000SZ
1991 Ducati 900SS
1996 Kawasaki ZZR600
2003 Transalp
2004 MV Agusta brutale F4
2003 Cagiva xtra raptor 1000
2012 Triumph Tiger 800
2019 Suzuki GSX-S 1000S
1991 Ducati 900SS
2003 Transalp
- Has thanked: 638 times
- Been thanked: 243 times
Well that might be a job for the spring now, or at least next year.
