Hello!
G0FHM
Re: Hello!
Post by G0FHM » Fri Jan 18, 2013 4:34 pm
I've got our bolts out... i'll go and have a measure. I know they are a 12mm head, but will measure and have a look at the length.
J
Has thanked: 80 times
Been thanked: 72 times
Re: Hello!
Post by sparki » Fri Jan 18, 2013 8:41 pm
:) cheers m8
KOCUK - 241
G0FHM
Re: Hello!
Post by G0FHM » Sat Jan 19, 2013 3:06 pm
Steve,
Had a look at the bolts, and have deduced the following:
12mm Flanged head. Thread is M8 (Haven't got a thread guage, but M8 nut fits fine). Overall length of shank is 15mm, with 10mm of thread & 5mm shoulder between head and start of thread.
Hope this helps!
J
Re: Hello!
Post by sparki » Sat Jan 19, 2013 6:40 pm
cheers m8... sorry if i appear a little thick here but..... i get the m8, 15 + 10 thing... but the shoulder? could you maybe send me a pic? sjparkinson@gmail.com would be great.. cheers m8
KOCUK - 241
G0FHM
Re: Hello!
Post by G0FHM » Sat Jan 19, 2013 8:08 pm
Steve,
The "Shoulder" is basically a blank, unthreaded portion.... so you have the hex head, 5mm of blank metal, then 10mm of thread!
Simples!
If you still need a pic, give me a yell!
J
G0FHM
Re: Hello!
Post by G0FHM » Sat Jan 19, 2013 9:01 pm
Had a word with my mate earlier... he is confident he can repair the seat bottom plate!
The foam is intact, as is the cover... there is just corrosion on about 25% of the left hand side for about 10mm, including the lip which has rotted. If anybody can do anything with metal, then he can! He's also going to have a look at the swing arm... and will plate it if need be.
Not as bad as we expected! Now to find someone to strip and powder coat the wheels.....
Re: Hello!
Post by sparki » Sat Jan 19, 2013 11:28 pm
Lol... Cheers m8. I read your first msg wrong and got confused ;) I'll get some 12.9 m8 16mm cap screws then . Cheers again
KOCUK - 241
G0FHM
Re: Hello!
Post by G0FHM » Sun Jan 20, 2013 1:09 pm
Steve,
Capscrews should do nicely. My Triumph is virtually all capscrews!
