pop up choke
pop up choke
Does the knob stay in the on position by itself ? or will it just spring back which is what mine is doing at the moment?
thanks
thanks
- Katgeezer
- Has thanked: 6 times
- Been thanked: 8 times
Re: pop up choke
There's a wavy washer that goes under the knob and provides a resistance to it springing back. They usually go missing. I don't think I've got a single one!!! Clothes peg on the sliding bit at the carbs while you put your gloves on then just ride.
You can get the washers still. A large fibre or rubber washer would probably work too if you can find one big enough. B&Q maybe?
Pop-Kat
Re: pop up choke
I saw the choke fixings on ebay the other day, not a lot of dosh, think it was listed under "Suzuki katana"
Pop-Kat
Re: pop up choke
found it
http://www.ebay.co.uk/itm/Genuine-Suzuk ... 3cd261b92d" onclick="window.open(this.href);return false;
Re: pop up choke
- Been thanked: 716 times
Re: pop up choke
Any thin washer will do just make sure it fits well around the centre of the choke knob and then bend it a bit.
It sits between the panel and knob.
Re: pop up choke
Seems to work ok now. Put a big rubber washer between the knob and the panel and i suppose it offers just enough friction to hold the knob when its on
Thanks for the info
Thanks for the info
Re: pop up choke
Complete choke knob set here http://page16.auctions.yahoo.co.jp/jp/auction/u48963735" onclick="window.open(this.href);return false;
cheap as chips too
cheap as chips too
KOCUK 046 Jez
to be continued
to be continued
- sparki
- Committee Member
- Has thanked: 80 times
- Been thanked: 72 times
Re: pop up choke
excuse my ignorance.... but how do you search on the yahoo site? sounds stupid i grant you but cannot work it out? would love to have a browse around and see whats what on it
